Hay Everyone,
I was just wondering if anyone knows if you can put an RB26dett engine and gear box, including the front wheel drive into an R33 GTST. Cause I was thinking of doing it......
HAs this been done before? Are the engine mounts the same? Will the GTST drive shaft fit and do you have to replace the diff?
I can't wait to here what you guys think.
Cheers
Gold Rays
https://www.sau.com.au/forums/topic/17541-rb26dett-in-a-r33-gtst/
Ive seen an RB26DETT (without the 4wd stuff) in a 4 door R33 and it wasnt as easy as just swapping everything over. It took about three days for a mechanic who specialises in skylines to iron out all the little problems. i think electrics were more of a problem than mechanical. it had bigger turbos, a powerfc and avcr too. that being said, make sure you reasearch it first....
I'd say it would be cheaper in the long run to sell your GTSt and buy a GTR.. Otherwise pick up a GTS4 and drop an RB26 into that, then you have ATTESA...
A mate of mine has put an RB26 into his GTS, engine dyno'd at over 700hp, thing is an animal in the dry in any gear... I like the grip of my GTR :D
Brett
i don't bother me if I can't get the FWD. I want to do what your mate did.
I heard you could buy some sort of 4WD kit for a GTST!!!
I will be doing all the installing work with help of a few mechanics for free, so i don't have to worry about the cost of that. Only the cost of the front cut.
Another question: Is the GTR chasis the same as a GTST?
Hi Gold Rays, last time I priced a half cut R33 GTR it was close enough to $12K, to that you would need to add the cost of an R33 GTR tail shaft, rear diff, rear uprights, brakes, drive shafts, suspension arms, fuel tank, fuel pump, rear outer guards, rear inner guards, panel beating, painting etc etc
Someone already said it, "I'd say it would be cheaper in the long run to sell your GTSt and buy a GTR"
Plus in the end you would still have a GTST, not a real GTR.
My thoughts anyway
All RB block patterns are the same so it should just bolt straight in. Don't know about the 4WD though.
And 1989 R32 GTR's are going for about 15K in Jap land ATM so you may want to just upgrade. Check out prestige motorsports mailing list.
http://www.prestigemotorsport.com.au/au/st...asp?StockID=833
If the link don't work just sign up.
Guest YZF-R1 Maniac
Here are another couple from Prestige motors. I have been receiving their emails for a while and they are getting really cheap.
http://www.prestigemotorsport.com.au/au/st...asp?StockID=892
http://www.prestigemotorsport.com.au/au/st...asp?StockID=897
Is that you Damien??(TasGTR)
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
