Ok so this gtr that i'll probably be getting (r32 gtr, 93 model) is making noises and dying out above 6k.
It's sort of like a intermittent ticking sound, that sounds like somethings blocked or ecu is cutting fuel a tiny bit or something is hampering the performance, and it's sort of popping a bit.
It only has 91 octane fuel in it at the moment as my dad was being a cheap ass, so i'm hoping it's just this but, i wouldn't think it'd have such an effect.
The dying is not a fuel cut or other cut, it's not that big and it seems sort of like blocked injectors, just above 5500rpm it doesn't seem to increase in speed, just maxes out.
i know the car has had afm troubles in the past and they have been replaced, so maybe something has let go in that area, but i'd expect to notice the trouble lower in the rev range
Any suggestions? I'm having a comp test done today, to check what condition the engine is, was just hoping it couldnt be turbo or anything like that
Also is a bit of a diff whine at low speeds, e.g. creeping in 1st, normal in these?
thanks
EDIT: Just got the compression test results, and it got 185 across the board, so i'm assuming the test was done with the car warm [b/]
Edited by r32 gts-turbo
https://www.sau.com.au/forums/topic/175552-gtr-maxing-at-around-5k-rpm/
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
