not between lower control arm, camber arm, and toe arm (not tie rods that are on hicas.. they control toe but they are tie rods) If you have no idea what your looking at i can post a pic with all the names of diff arms
https://www.sau.com.au/forums/topic/175679-gts-gts-t/#findComment-3219269
You're talking about the traction rod, not toe arm. Toe arms are used on non hicas equiped cars.
It's worth while checking the size of your lower control arm bushes too as there are 2 different sizes about and they are not interchangable as the mounts on the subframe are different.
https://www.sau.com.au/forums/topic/175679-gts-gts-t/#findComment-3219525
if you could that would be awesome man
and someone said something about the subframe......i think thats whats most damaged :dry:
https://www.sau.com.au/forums/topic/175679-gts-gts-t/#findComment-3220322
    • Thanks man, I appreciate that. I'll keep it in mind going forward, important to know.
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
