^^^Yeah, but then there's the issue of tyres and brakes. They're off the hook this time cos of the short notice :nyaanyaa:
haha well ill see how i go then, last time i touched the brakes was when it was freshly imported which was over 1 and a half years now, and tires have shit traction being old, i think ones got a puncture too haha
i think ill take it easy on everything as i just dont think its ready for much stress yet lol
  • Replies 47
Posted Images
You just have to have a bit more common sense than me and back off when you feel tyres start to go greasy or feel brake fade coming on.
I wasn't that smart and came home with brake pads looking like this
post-21548-1184077685_thumb.jpgpost-21548-1184077692_thumb.jpg post-21548-1184077698_thumb.jpgpost-21548-1184077703_thumb.jpg
Edited by salad
The cheapest 'possibly' suitable are Bendix Ultimates.
I bought a set a while back and they cost me ~$100 for fronts and a little cheaper for the rear. Or was it vice versa. :S
Either way, shop around some charge like a wounded bull. I think I got the pads from Motormates.
Salad, Are ultimates suitable? How did yours mates ultimates hold up?
The pads I've got in right now are TRW Lucas. Available from ABS, the fronts cost me $55, going to get some rears soon as the Bendix HD in there now probably wont last...
I've been told they are used by a few Saloon Cup cars so they stand up to the heat alright. I'll be able to tell you exactly how they do after Saturday though :)
Just going by feel on the street though, they are miles ahead of the Bendix HD, so I'm quite interested to see how they fare with proper hard driving.
My friend's Bendix Ulitmates seemed OK, he didn't have the problem of them falling to pieces like my HDs, but his car is a full stripped out track car, so a good 100kg lighter or so. Not too sure what the go is, other people have used them on the track and they've just crumbled after a few laps.
Edited by salad
The whole mentality of myself buying them was "$55!?!?!?! How can I lose!?" :)
Only time will tell now, I'm tossing up whether or not to chuck new rear pads in tomorrow or not... There's a fair bit of meat left in the Bendix but they wore down really quick last time. Maybe I'll just toss a coin :)
Edited by salad
Gates at 8, driving starts at 10, be there before then to make sure you have enough time to sign on and get ready if you need to do anything else.
Would anyone going like to meet on the way? Say at the Caltex on Pt Wakefield?
Good fun day :D Few skylines out there too, mostly in the 1day licence group.
Managed a best lap of 1.24.1, Oh so close to my goal of getting into the 23s. Probably could've done it with another session, but pads were getting low and so was fuel, didn't want to chance it.
The Lucas pads are OK, the pads themselves didn't seem to fade heaps, but it was noticable after 5 or 6 laps, but no where near the fade of the Bendix HDs. I think most of my fade problems were because of the fluid, felt like there was a bit of air in there. They held together, but they have worn down a fair amount now, about 1mm till the indicator thing and they were pretty much brand new when I went out. But for $55, you cant really complain :happy:
Now the rest of you, get out there soon! :P
Oh, and bring a jerry can of spare petrol :laugh: I used about 2/3s of a tank in ~25laps (3x15min sessions), with only around 180rwkw, so you guys with big power should guzzle a fair bit...
Edited by salad
haha fun day, brakes died straight away and left me with barely any braking coming into the corners, tires were terrible and understeer was shocking, then boost controller got a hole in the tubing which meant i couldnt hold the throttle open other wise it would boost 15+psi, then rear tires went and meant the last session was just me sliding everywhere.
but it was fun and pretty happy with how the suspension and engine held up, now just to replace: tires, brake pads, clutch and diff.
haha showza apparently recorded one of my lap and he says it was 1:40 or soemthing which sounds about right. that was the 2nd session where i was half throttle on the straights to stay behind a corrolla as i was trying to get used to having no brakes. later on i was going full throttle down the straights and also got used to the track but still had to back off REALLY early to give my brakes a rest so the time wouldnt have been affected heaps.
for the first 2 laps as long as i didnt push it too hard i had better grip, but u could see as the tires and brakes just deteriorated the guys in front would just start leaving me for dead so i would be really interested to see how i go with some good brake pads and semi slicks.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
