Hi there,
has anyone ever bent a release lever? i was at Wakefield yesterday and during the last session i could'nt change gear without crunching. To get home i had to adjust all the free play out of the pedal , even after that i still have to push the pedal extremely hard against the floor to be able to change gear.So if you've had this problem before please let me know did you just repair the bent one or replace it or repair and strengthen it?cheers
btw it isnt air in the fluid it has been bleed with new fluid!
https://www.sau.com.au/forums/topic/175901-clutch-release-lever-on-r33/
Hey Plynx,
Yes i have a heavy duty Exeedy clutch and pressure plate its been in there for probably two years or more, ive never had a problem with it, but i have noticed that the take up of the clutch seems to change sometimes lower sometimes higher not by much,the free play remained the same thou. I could'nt see any problems in the pedal area while i was adjusting the free play out to get me home from the track,i might take another look.........i think im going to pull the box out and rebend the lever then strengthen it with some welded ribs.
thanks for your reply. cheers
Brother ! My car had excatally the same clutch and it was also in for about the same time before it went and it was the clutch pedal box. I took it to a couple of clutch places and the reconed that I bent the new clutch when I put in the 3ltre conversion. Charged me an extra $350 to rebotton the old excedy and put it back in. All they did then was adjust the clutch rod up to the max and gave it back. Lasted about 2 days ! Took the car to another clutch place for a second opinion. They said it was either the master cylinder or slave cylinder. Recoed them as well ! Took it back again and was ready to kill people when the guy got upside down under the car and spotted the busted spot welds on one side of the pedal box thats why it was only partly working very much like yours ! Took it out myself and fully weilded it up and that fixed the bastard ! If you need a hand with it let me know I be happy to help a brother out. Ive also got a spare leaver that I was going to box in for extra strength. Rebending it might give you stress fractures and youll be back where you started.
Thanx Plynx,
You were right, so you can say "i told ya so" again lol, cant thank you enough so i'll return the favour when the 3litre is ready to go in, call me and i'll be there.cheers brothersan
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
