i will be convering from my gfb bleeder ;)
they are good..
i use them on all my cars. one currently on the 180sx.
and i got 3 spares i brought in bulk cause they are a great controller.. but shane likes ebc..
good price. :)
https://www.sau.com.au/forums/topic/176092-sold/#findComment-3223386
i found it held 10 psi really nice until i put high flow cat on then it started spiking between 1-3 psi as the revs went high in first gear fine in every other gear but it was a really cold the other night... decided to get EBC anyway
https://www.sau.com.au/forums/topic/176092-sold/#findComment-3224344
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
