hey man, how bad was the misfire?
im in the same boat.
i got fmic, full exh, and apexi pod..
running low of 8psi and hi of about 12-14psi and i get misfire on a cold night even on low lol
misfires only after like 5000rpm tho.. otherwise the power hits like a rocket :)
Edited by Ultimategtr
https://www.sau.com.au/forums/topic/176595-new-coilpacks/#findComment-3231089
misfires only after like 5000rpm tho.. otherwise the power hits like a rocket :D
yeah mostly after 4500-5000
like hitting a very spongey wall
all gone now though its great
https://www.sau.com.au/forums/topic/176595-new-coilpacks/#findComment-3232075
if you dont mind me asking how much was the coilpacks? and where did you get them from???
Ashneel, you fag!
Congratulations on your ride, mate...remember to send me some Photos!!
Oh, and let me know your very first Skyline 1/4mile time.... :-)
Enjoy!
Chanz
https://www.sau.com.au/forums/topic/176595-new-coilpacks/#findComment-3232861
i got my coilpacks from SAU trader Slide. $530 delivered, excellent coils and four hundred cheapwer then auto barn and super cheap.
Good luck,
Aif.
https://www.sau.com.au/forums/topic/176595-new-coilpacks/#findComment-3235520
  • 3 weeks later...
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
