hey all its time to sell my 32 as im trying to get money to buy another car thats currently for sale
i really need this sale quick as i dont know how long this other car will last
price is $13,000
'89 128***k's
5spd rwd
3" turbo back exhaust with de-cat pipe
tein height/damper adj coilovers
bigger adj castor rods with solid joints
newly fitted FMIC
boost T set @14psi
autometer boost gauge
greddy turbo timer
GTR front bar
pod filter
alpine stereo
head gasket done a week after i bought the car bout 3 months ago
new tyres front, near new on rear
jus past pits a 2 months ago
rego till nov
Pretty much had it off the road for 2 months now koz i lost my licence, done under hoon laws, so the cars maybe been driven for a month after havin the head done. Its still as is after it passed the pits, ride heights jus legal etc so your not gonna cop a sticker from the cops driving it home, paint is in good nik, nice glossy black, completly de-baged so its ready for sum dark tint to give that vip look, the interior is clean no tears in the seats or peeling dash just the vinyl around th door handle is starting to peel very small though
The previous owner also had the timing belt, water pump an viscous fan replaced so all the hard expensive works been done to keep the car running
i dont really want any time wasters or people telling me they have to wait for a loan to approve but dont mind hearing what you's have to say :)
koz i need the money soon
locality- perth WA
cheers guys
heres some pictures to convince you haha
Edited by G0TB00ST
https://www.sau.com.au/forums/topic/176662-sold/
price is $13,000
'89 128***k's
5spd rwd
newly fitted FMIC
boost T set @14psi
greddy turbo timer
GTR front bar
pod filter
alpine stereo
rego till nov
i dont really want any time wasters or people telling me they have to wait for a loan to approve but dont mind hearing what you's have to say :D
locality- perth WA
cheers guys
Alright mate no worries just message me sometime if your interested to check out my car my number is 0439986495 cheers wes
https://www.sau.com.au/forums/topic/176662-sold/#findComment-3263956
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
