Hey guys.
I got some endless pads (so i believe) from my mechanic, before i went on track day, as my rear pads were down to the metal.
(sorry dont know exactly what model it is or any details- but they seems like endless pads)
I had no problems whats so ever at track day or street driving, but they just squeal too much.
UPDATE: Ok the standard pads i put on squeal a bit too.. Not as much as the one im selling, so maybe its something else to do with my car :D
I dont know if its just my car or what!!
So today i decided to go buy some standard pads.. Not like i need anything fancy..
So these are up for sale. Seriously only used for 1 month MAX!!
i drove the standard pads today, and the endless pads bite so much harder( ie is better).. I could feel the difference already!!
Anyways..
Item: R33 Rear brake pads (also fits s15 rear i think) SOLD!!
Condition: excellent.. 80%-90% meat left on them..
Price:SOLD SOLD SOLD!!
Pics:
Item 2: R33 Rear Sway bar
Condition: Excellent
Reason for sale: Upgraded to thicker kmac sway bar- bought from a member here, so no longer needed
Price: $60 bucks
Pics:
The black one... not the orange one!!
Edited by siddr20
UPDATE: Ok the standard pads i put on squeal a bit too.. Not as much as the one im selling, so maybe its something else to do with my car :domokun:
SO maybe, these pads wont squeal on your car????
Ok so i heard from a friend last nite, that the rear pads of the 33 wont fit the s15..
But my mechanic said it would.. hmm
Can anyone confirm? lol
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
