hey guys, my girlfriend is on her p's 6months away from opens and is planning on getting a turbo manual import in the near future, but she only has her auto licence at the moment and she was wondering that if she gets her manual licence now will she b allowed to drive a turbo manual car since these new laws have come in or will she have to wait till shes 25?
thanx
Edited by shane32
https://www.sau.com.au/forums/topic/176796-girlfriends-licence/
thanx
Depends, what state you in, i know if your in QLD the new laws only affect people that got their licence after the restrictions started.
we're in QLD and yes i no that it only applys for ppl that got there licence after the new laws came out but thats wat im asking, shes had her auto licence 2 and a half years ago before the laws but now she is gettin her manuals with the new laws b for her aswell?
i would have thought that when you go for your manual licence your not actually getting a new licence, it is more a change to the licence i know some people that had their opens but where on an auto licence went for their manual test and didn't go back on p's so i think she will be ok, but i would check with the transport dept
it is just getting a condition changed, it shouldn't be that big of a deal
