Brand New HID kits
5000k-15000 colours are available as well as special colours like GOLD, PINK, GREEN, PURPLE (30000k), DARK BLUE, RED and PURPLE.
All bulb types are available (H3C and H4 high/low is $35 extra, also uses super thin ballasts) , most skylines use H1 for low beam
In the package you get (2 bulbs , 2 ballasts , connecting wires, installation manual)
Specifications:
V in : 9-16V
V norm : 13.5V
V start 23KV max
I in Max : 20A
I norm : 3.4A
P out : 35W norm.
T case : -40℃±105℃
Over voltage protection
Low voltage protection
PRICE for forum members: $165/kit
PM me if interested or Call 0411268451
Cheers!
Heres my example of a 6000K kit on an R33 S2, very nice white colour white a hint of blue, not too strong and looks amazing
Edited by Mid_Nite_R33
https://www.sau.com.au/forums/topic/177730-brand-new-hid-kits-5000-15000k/
Just a few questions... :thumbsup:
1. Are the H1's a direct swap in for R33 GTST, any modifications required?
2. Have you seen them in action?
3. What is the wattage?
4. Any warranty?
5. What brand are they?
6. Why so cheap compared to shop prices?
Thanks!
Edit: I've also heard that H.I.D.'s can be a bad idea for some car's... any idea how they go in the series 2 r33? I don't want to blind people :thumbsup:
Edited by bombastic
4. Any warranty?
Thanks!
pm sent
I look forward to seeing pics! Which colour temp did you get? Also, did you do any funky wiring with the high beams so you don't have to wait 30 seconds between switching high beams on and off?
I was thinking a chunky capacitor wired in to the ballast's supply combined with a mod like this would allow the xenon's to stay on even during the switching time from low to high beams. I think there is a simpler tutorial but it involves cutting existing wiring...
UPDATE
I just got my 2 samples in, one is sold and the other I just installed in my R33gtst
Will have pics to show tonight to those who are interested..
PICS ARE UP !
I got the 6000k kit, loos real good, hard to capture on a digital camera though.
No i heavent tryed the high beam trick yet.... let me know what you find
PICS ARE UP !
How is road visibility, angle/dispersion compared to original lights?
Visibility is great and the distribution of light in my headlights seems very good, everything is so much more clear, you can tell when you drive next to a car with normal halogen that you have something good.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
