Hey guys, Ive been reading few threads about the 4wd system in a r33 gts-4. theres been few different comments and im confused lol..im trying to figure out how the gts-4 4wd system works..is it RWD until u make a turn then 4WD kicks in for control or is it 4WD all the way and neva turns off? lol is there some sort of torque split?
https://www.sau.com.au/forums/topic/177936-4wd/
The Attessa E-TS system calculates its operation from a number of sensors such as the ABS wheel sensors, on-board G-sensor, etc. It uses these inputs to calculate upto 100 times a second if it will be beneficial to provide front torque. So basically if you enter a corner and the Attessa E-TS computer thinks you need assstance it can send upto 50% of torque to the front wheels to correct and stabilise the car.
So yes it is rear wheel drive biased, which means until you really need it the car runs in rear wheel drive then has the option to start providing front torque depending on the situation. It does this by using hydraulic pressure in the transfer case to apply clamping pressure to wet clutch packs. The more pressure it applies, the more torque is transferred to the front wheels. It uses a fluid similar to automatic transmission fluid (ATF) to achieve this.
Even for present day its a very advanced system and most people dont really understand how it works completely. I have a GTR and thats what my info is based on but im pretty sure the GTS-4 is the same system, however the Attessa E-TS is tuned differently for different models.
Regards,
Deren
Edited by Godzilla32
https://www.sau.com.au/forums/topic/177936-4wd/#findComment-3247814
Nissans 4WD system which transfers power and braking force where it is needed for best performance. Torque is split between front and rear wheels while braking force is split independently to all four wheels utilising ABS. In ordinary driving conditions torque is delivered purely to the rear wheels, however when the car is pushed the computer engages the front wheels and calculates the amount of power split between front and rear.
Edited by Rob_C110GTR
https://www.sau.com.au/forums/topic/177936-4wd/#findComment-3247826
the r33 have at least 5% going to the front wheels all the time
The basic way attessa works is to put minimum power to the front wheels through the corner so u have the handling of a rwd car and power to all wheels as u leave the corner so u have the grip of a 4wd car
Edited by GTR32GUS
https://www.sau.com.au/forums/topic/177936-4wd/#findComment-3248333
If there is some power going to the front wheels all the time, there is a problem. If you research it you will find it is not mean't to have torque all the time. One common way of tricking the Atessa E-TS system is to fit staggered tyres front to rear, instead of the same width all round as it should be. I have heard this can bring on more front torque earlier. I think doing this is also known to run front torque constantly too. So this maybe why you have the minimum of 5% front torque. Could also be something to do with air in the system. If you read the DIY section there is the procedure for air bleeding of the 4wd system. However as i previosly mentioned the different model skylines with the Atessa E-TS system have it tuned differently, but only to bring in more front torque earlier, not all the time.
Regards,
Deren
https://www.sau.com.au/forums/topic/177936-4wd/#findComment-3249620
O ok, well thanks for that guys..I have a 97 S2 r33 GTS-4, so basically my r33 has the ATTESA-ETS system running similar to that of the GTRs except tuned differently for when front torque is transfered hey? and btw, what fluid do I top up the system with? that bottle in the boot on the drivers side..I heard I could use Nissan ATF fluid?
https://www.sau.com.au/forums/topic/177936-4wd/#findComment-3250531
Nissan recommend to use Nissan D-matic fluid. Im not 100% sure if its safe to use normal ATF (Dextron) or if they just want the money coming back to them. Unless its hell expensive, id say use the nissan stuff just to play it safe. If your feeling adventurous you could even bleed up the system to make sure its working as well as it can be. See the DIY section.
Deren
https://www.sau.com.au/forums/topic/177936-4wd/#findComment-3252206
Hey guys, i THINK there something wrong with my 4WD system, my 33S2 GTS-4 makes a high pitch humming/whining noise? sounds like its coming from the back driver side. Could this be a pump for the ATTESSA-ETS or something? is it normal?..and also my 4WD dosen't feel as good. I took it out 4 a test around a corner and my 33 skidded abit and felt as if no torque was delivered to the front D=..I checked the fluid level in the boot and its bout 5mm under MIN level. Is that the reason why my 4WD is making noise and not working properly? or shuld I try bleed the system aswell?
thanks for ne help!
https://www.sau.com.au/forums/topic/177936-4wd/#findComment-3252995
Oops ok sorry my mistake. I'll just stick to the 32's huh lol...
I would top up your fluid and give it a bleed as its detailed in the DIY section or manual if you have it.
The noise you are hearing is probably coming from the transfer case as its positioned to the right side.
https://www.sau.com.au/forums/topic/177936-4wd/#findComment-3255427
o ok, thanks for that. might give it a try. if the noise is from the transfer case if there anyway to quiten it down? or is it normal lol..1 more thing..is the 4wd in the r33 meant to engage almost instantly?. I skid 4 about 0.5-1sec and dont feel any front torque :S
Edited by OoskylineoO
https://www.sau.com.au/forums/topic/177936-4wd/#findComment-3256151
well, thats hard to answer. 4wd can't fix an understeer problem so ATTESSA might be doing its thing, but it can't create more grip overall than the 4 tyres can give. You need to think about what is sliding (front, rear) and why (power, lateral or sideways motion?)
Bring it by the next sau track day and we can see if it is working ok :laugh:
https://www.sau.com.au/forums/topic/177936-4wd/#findComment-3256679
Hey might mean when he launches it. In that case it possibly needs a bleed. Still, you need to you work out if infact its just the rear wheels spining or all four. Another thing to consider is the health of your clutch, being 4wd it places alot more load on your clutch during hard launches. I know myself that hard shifts wont always make a clutch slip but hard launches will with the grip four wheels provide.
A whine from the transfer seems to be fairly normal.
https://www.sau.com.au/forums/topic/177936-4wd/#findComment-3256689
i find the best way to check the 4wd is working is to look at the gauge. Also there is an orange 4WD warning light that comes on if there is a problem.
Next wet day accelerate hard away from the lights, if your wheels start spinning the torque split gauge should go up as the computer transfers torque to the front wheels. It should work in a straight line not just around corners.
https://www.sau.com.au/forums/topic/177936-4wd/#findComment-3259570
Should be pretty quick but as Duncan said there should always be 5% front torque in the r33 so your car should wheelspin even less than an r32 with the different programmed Attessa seeing as its always engaged to some extent...
https://www.sau.com.au/forums/topic/177936-4wd/#findComment-3261220
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
