Hey guys, Ive been reading few threads about the 4wd system in a r33 gts-4. theres been few different comments and im confused lol..im trying to figure out how the gts-4 4wd system works..is it RWD until u make a turn then 4WD kicks in for control or is it 4WD all the way and neva turns off? lol is there some sort of torque split?
https://www.sau.com.au/forums/topic/177936-4wd/
The Attessa E-TS system calculates its operation from a number of sensors such as the ABS wheel sensors, on-board G-sensor, etc. It uses these inputs to calculate upto 100 times a second if it will be beneficial to provide front torque. So basically if you enter a corner and the Attessa E-TS computer thinks you need assstance it can send upto 50% of torque to the front wheels to correct and stabilise the car.
So yes it is rear wheel drive biased, which means until you really need it the car runs in rear wheel drive then has the option to start providing front torque depending on the situation. It does this by using hydraulic pressure in the transfer case to apply clamping pressure to wet clutch packs. The more pressure it applies, the more torque is transferred to the front wheels. It uses a fluid similar to automatic transmission fluid (ATF) to achieve this.
Even for present day its a very advanced system and most people dont really understand how it works completely. I have a GTR and thats what my info is based on but im pretty sure the GTS-4 is the same system, however the Attessa E-TS is tuned differently for different models.
Regards,
Deren
Edited by Godzilla32
https://www.sau.com.au/forums/topic/177936-4wd/#findComment-3247814
Nissans 4WD system which transfers power and braking force where it is needed for best performance. Torque is split between front and rear wheels while braking force is split independently to all four wheels utilising ABS. In ordinary driving conditions torque is delivered purely to the rear wheels, however when the car is pushed the computer engages the front wheels and calculates the amount of power split between front and rear.
Edited by Rob_C110GTR
https://www.sau.com.au/forums/topic/177936-4wd/#findComment-3247826
the r33 have at least 5% going to the front wheels all the time
The basic way attessa works is to put minimum power to the front wheels through the corner so u have the handling of a rwd car and power to all wheels as u leave the corner so u have the grip of a 4wd car
Edited by GTR32GUS
https://www.sau.com.au/forums/topic/177936-4wd/#findComment-3248333
If there is some power going to the front wheels all the time, there is a problem. If you research it you will find it is not mean't to have torque all the time. One common way of tricking the Atessa E-TS system is to fit staggered tyres front to rear, instead of the same width all round as it should be. I have heard this can bring on more front torque earlier. I think doing this is also known to run front torque constantly too. So this maybe why you have the minimum of 5% front torque. Could also be something to do with air in the system. If you read the DIY section there is the procedure for air bleeding of the 4wd system. However as i previosly mentioned the different model skylines with the Atessa E-TS system have it tuned differently, but only to bring in more front torque earlier, not all the time.
Regards,
Deren
https://www.sau.com.au/forums/topic/177936-4wd/#findComment-3249620
O ok, well thanks for that guys..I have a 97 S2 r33 GTS-4, so basically my r33 has the ATTESA-ETS system running similar to that of the GTRs except tuned differently for when front torque is transfered hey? and btw, what fluid do I top up the system with? that bottle in the boot on the drivers side..I heard I could use Nissan ATF fluid?
https://www.sau.com.au/forums/topic/177936-4wd/#findComment-3250531
Nissan recommend to use Nissan D-matic fluid. Im not 100% sure if its safe to use normal ATF (Dextron) or if they just want the money coming back to them. Unless its hell expensive, id say use the nissan stuff just to play it safe. If your feeling adventurous you could even bleed up the system to make sure its working as well as it can be. See the DIY section.
Deren
https://www.sau.com.au/forums/topic/177936-4wd/#findComment-3252206
Hey guys, i THINK there something wrong with my 4WD system, my 33S2 GTS-4 makes a high pitch humming/whining noise? sounds like its coming from the back driver side. Could this be a pump for the ATTESSA-ETS or something? is it normal?..and also my 4WD dosen't feel as good. I took it out 4 a test around a corner and my 33 skidded abit and felt as if no torque was delivered to the front D=..I checked the fluid level in the boot and its bout 5mm under MIN level. Is that the reason why my 4WD is making noise and not working properly? or shuld I try bleed the system aswell?
thanks for ne help!
https://www.sau.com.au/forums/topic/177936-4wd/#findComment-3252995
Oops ok sorry my mistake. I'll just stick to the 32's huh lol...
I would top up your fluid and give it a bleed as its detailed in the DIY section or manual if you have it.
The noise you are hearing is probably coming from the transfer case as its positioned to the right side.
https://www.sau.com.au/forums/topic/177936-4wd/#findComment-3255427
o ok, thanks for that. might give it a try. if the noise is from the transfer case if there anyway to quiten it down? or is it normal lol..1 more thing..is the 4wd in the r33 meant to engage almost instantly?. I skid 4 about 0.5-1sec and dont feel any front torque :S
Edited by OoskylineoO
https://www.sau.com.au/forums/topic/177936-4wd/#findComment-3256151
well, thats hard to answer. 4wd can't fix an understeer problem so ATTESSA might be doing its thing, but it can't create more grip overall than the 4 tyres can give. You need to think about what is sliding (front, rear) and why (power, lateral or sideways motion?)
Bring it by the next sau track day and we can see if it is working ok :laugh:
https://www.sau.com.au/forums/topic/177936-4wd/#findComment-3256679
Hey might mean when he launches it. In that case it possibly needs a bleed. Still, you need to you work out if infact its just the rear wheels spining or all four. Another thing to consider is the health of your clutch, being 4wd it places alot more load on your clutch during hard launches. I know myself that hard shifts wont always make a clutch slip but hard launches will with the grip four wheels provide.
A whine from the transfer seems to be fairly normal.
https://www.sau.com.au/forums/topic/177936-4wd/#findComment-3256689
i find the best way to check the 4wd is working is to look at the gauge. Also there is an orange 4WD warning light that comes on if there is a problem.
Next wet day accelerate hard away from the lights, if your wheels start spinning the torque split gauge should go up as the computer transfers torque to the front wheels. It should work in a straight line not just around corners.
https://www.sau.com.au/forums/topic/177936-4wd/#findComment-3259570
Should be pretty quick but as Duncan said there should always be 5% front torque in the r33 so your car should wheelspin even less than an r32 with the different programmed Attessa seeing as its always engaged to some extent...
https://www.sau.com.au/forums/topic/177936-4wd/#findComment-3261220
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
