Hey guys,
I have been offered the chance to provide you with another top group buy!
This time, we are going for the exhaust side of the turbo, not the inlet as with my Silicone Inlet Pipes. (Silicone Clicky Clicky)
STAINLESS STEEL SPLIT FRONT DUMP PIPE
The pipe features a 3 inch primary, 1.5" split section that rejoins main pipe later on.
Stainless Splitter between wastegate port and exhaust port to separate the exhaust gases between turbine and wastegate.
2.3mm Wall Thickness pipe for strength and durability, and the factory O2 sensor can be screwed into standard position.
Normal 1 off price is over $250 but in this group buy I can do them for you at $199!!
Freight is extra, and that will set you back:
MELBOURNE/SYDNEY - $25
PERTH/BRISBANE - $30
DARWIN - $45
HOBART - $40
Parts will arrive in boxes and bubble wrapped for safety.
Remote areas ie. outside metro areas will need to be addressed on a case by case basis.
Timing?
Once we have 20 people, the order will go ahead, expect to wait between 3 and 4 weeks for your shiney new pipe to arrive.
Here's some pics.
So, who's keen?
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
BASS OUT
Hi Mate,
Unfortunately this in only for the Split Dump/Front.
I would sell that front pipe to somebody who is going for something like a GT-RS with it's custom dump and get yourself a big split dump in this group buy :(
These are made in Taiwan.
Like the vast majority of all exhaust components you will find.
Top quality as sold by several other retailers.
Guest
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
