Hi DJ_L3ThAL, if you can stretch to $1400 incl freight, you have a deal.
Sciby, what you sold yours for doesn't really interest me. I'm asking $1400 for mine.
  • Replies 44
Well, considering that you said that the last set that sold on the forums (mine) was for $2000 on ebay indicates that it *does* interest you... also, you pm'd me, asking how much I sold them for... more interest... but don't let that stop you from trying to get more money out of people by stretching the truth.
Good luck with your sale.
  • 1 month later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
