Originally posted by hungry6
single plate 3 or 5 puck sintered ceramic will more than do the job, and it's more streetable than a multi plater. DAIKIN  HAVE THEM FOR ABOUT $350 NEW
hi, Hungry6..
could you tell me more about this clutch? what power rating of it? and most important is where I can get one? thanks..
Originally posted by mrskyline777
but there great fun strong as drivability is lost a bit but you dont notice it that is exchange im not that keen on ceremic
mrskyline777..
can you tell me more of this clutch? thanks..
by other name,it's EXEDY most good clutch shop will be able to source one. prolly the number one favourite clutch used in japan and here for cars running upto 6-700 hp and it's alot lighter than multiplater and being ceramic it's has HUGE grip and wears really well, but it cannot be used with billet allumium flywheel. but yeah they've been around for ages. my recom. used it with a chrome moly flywheel with a 3500lb pressure plates and if u got the hp 100k/hr+ wheelspin here we come.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
