what can i say.. silver bumpers on a yellow Stagea don’t look "that bad".. or at least that's what my girlfriend told me as i looked at my car in disgust after putting them on
Its fantastic to see what you find when you take parts of the car off.. looks like the car has had a bad hoist experience :| (drivers side)
a big bad chain of events has lead to this.. but will give a good result i hope! basically i took the entire kit off to go in for repair this week (as every part of the kit has some sort of crack on it.. both from when it was in Japan and here in Australia :rolleyes: ) so the silver bumper bars have gone on the car to keep it on the road and driveable as it’s my daily car.. plans are to keep the rear bar and side skirts but sell the front bar (once its repaired) and the dayz guard flairs to make way for the R34 GTR front end and freshly repaired rear and sides..
i also just got my one of my wheels back from being repaired.. she has degenerated a fair bit :thumbsup: but everything is looking extremely bright for the end of the month :ph34r:
but its not all bad, i got a nice little surprise when i was taking off the rear bar.. i found this tool under the carpet :) (not the removable panel that covers the spare, but the panel that has 3 10mm's holding it down on the drivers right)
https://www.sau.com.au/forums/topic/179476-chicks-dig-it/
yup.. defiantly looks like a taxi :P that was my first thoughts when i saw it :( the colour match is horrible... i was thinking about getting the standard bars sprayed before installing but keeping it ugly is more motivation to get the work done faster!!
not sure who will be doing the work yet.. im going to take it around for quotes on weds..
it looks like its been "repaired" before :)
I’m going to get the entire kit professionally restored and strengthened (unlike whats been done before) so this sort of shit doesn’t happen again (at least for a while, who knows being fibreglass)
i got some strange looks driving today.. i can pin point the meaning of "wtf" down to the look one guy in a liberty b4 gave me today :( not enjoying this one bit
no one has jumped in the back yet! but i have my meter and 300% extra stagea charge ready :D
https://www.sau.com.au/forums/topic/179476-chicks-dig-it/#findComment-3272414
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
