It doesn't usually work very well. There are 2 options I forget, my mechanic set them both to 10%. It improved slightly, but not all that much. Changing your decelaration habits is the best way to stop it happening.
Edit: I think the setting is "Dec. Air" and has Lo and Hi settings or something.
Originally posted by Grim
Thanks but the safc is capable of correcting the problem...
As I already said, no it's not. You may see some improvement as I did, but also as with me and most other people it won't cure it. Set both settings to10% and see how you go.
Guest INASNT
grim u rice boy did u get a atmo venting bov??
remember we tried to set the dec air function with my blitz atmo and the s-afc?? if u dont remember, well it didnt work, it seemed like it worked but when u do a cold start the engine wont idle properly, its goes all crazy. In the end i had to turn the dec air thing off!!
Guest INASNT
I thought that was cos your BOV was mounted and sealed badly and was leaking air. plus i don't think we tried very hard to tune the dec-air feature....
nope i had my stock bov blocked and the blitz recoed with new springs.
The best thing i did was pissing the blitz bov off and going back to the stock bov!!
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
