G'day, it's come time to sell the GTR.
Tens of thousands have been poured into this car.
Mods as follows
$13,000 in reciepts for rebuild
Engine only has 1,500kms on it
Brand new nissan r33 gtr crank
Eagle forged rods
CP forged pistons
N1 oil and water pumps
Everything has been machined etc
Apexi power FC ecu with hand controller
3.5" stainless system
new extreme button clutch
nismo fuel reg
blitz pod filters
blits bov's (not yet installed)
It made 311awhp (232awkw) at Silverwater automotive on 14psi boost pressure
Very fast on the street.
It has white nismo gauges, nismo dash (320kmph speedo, 10,000rpm tacho)
High quality sound system
Nismo steering wheel
18" shadow rims with 255 rubber on all 4s
Bilstien adjustable suspension.
Theres probably alot i have forgotten.
One of the neatest gtrs ive seen, no dings, scratches, interior is near perfect etc etc.
Mature owner 40 years old.
Selling due to needing a family car.
This car is an awesome base for a big horsepower GTR or a very reliable street car.
The bottom end is built to hold alot of horsepower.
https://www.sau.com.au/forums/topic/180201-r32-gtr-24000-ono/
wanna swap a pajero exceed 2002 and u gimmie cash?
ill give you the passanger seat and u give me 5k ontop?
iv spent too much on my car to sell it off for anything under 18k after this turbo/suspension setup
  • 1 month later...
So was that $14,000 for the one rebuild or 2 or 3?
one rebuild mate, it hasnt just had a set of rings thrown in. If you'd done something like this before you'd know its not cheap.
Have all reciepts to prove to the doubters.
Standard turbos and injectors mate. The bottom end is done, all she needs is some bigger turbos and injectors and this baby is ready for big HP.
The base line is there for a tough realiable engine. The hard work has been done.
I believe you but if im not wrong isnt this the same car that was for sale mid last year when it also had spun a bearing ? I think it would be nice for people to know the history of the car...
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
