G'day, it's come time to sell the GTR.
Tens of thousands have been poured into this car.
Mods as follows
$13,000 in reciepts for rebuild
Engine only has 1,500kms on it
Brand new nissan r33 gtr crank
Eagle forged rods
CP forged pistons
N1 oil and water pumps
Everything has been machined etc
Apexi power FC ecu with hand controller
3.5" stainless system
new extreme button clutch
nismo fuel reg
blitz pod filters
blits bov's (not yet installed)
It made 311awhp (232awkw) at Silverwater automotive on 14psi boost pressure
Very fast on the street.
It has white nismo gauges, nismo dash (320kmph speedo, 10,000rpm tacho)
High quality sound system
Nismo steering wheel
18" shadow rims with 255 rubber on all 4s
Bilstien adjustable suspension.
Theres probably alot i have forgotten.
One of the neatest gtrs ive seen, no dings, scratches, interior is near perfect etc etc.
Mature owner 40 years old.
Selling due to needing a family car.
This car is an awesome base for a big horsepower GTR or a very reliable street car.
The bottom end is built to hold alot of horsepower.
https://www.sau.com.au/forums/topic/180201-r32-gtr-24000-ono/
wanna swap a pajero exceed 2002 and u gimmie cash?
ill give you the passanger seat and u give me 5k ontop?
iv spent too much on my car to sell it off for anything under 18k after this turbo/suspension setup
  • 1 month later...
So was that $14,000 for the one rebuild or 2 or 3?
one rebuild mate, it hasnt just had a set of rings thrown in. If you'd done something like this before you'd know its not cheap.
Have all reciepts to prove to the doubters.
Standard turbos and injectors mate. The bottom end is done, all she needs is some bigger turbos and injectors and this baby is ready for big HP.
The base line is there for a tough realiable engine. The hard work has been done.
I believe you but if im not wrong isnt this the same car that was for sale mid last year when it also had spun a bearing ? I think it would be nice for people to know the history of the car...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
