hey guys just got my car dyno yesterday and before i had it dyno they notice that i had cooland leaking from the water pump. would i have to replace the water pump or just the seal?? if it was to be the water pump where can i get a new or aftermarket one??
https://www.sau.com.au/forums/topic/180615-coolant-leak/
hmmm, it really depends
if could just be leaking from the base due to a seal failure
or it could be that the shaft of the waterpump is rooted
if it's the first one, remove the waterpump, put new seal on it and put it back in, they have a pretty long shelf life anyway
if it's the shaft, then you'll be needing a new one, scope out forums, ebay and trade places where you live, I think i got mine for $70 last time I needed it, which wasn't too bad a price, but I guess I could've searched for longer and found a cheaper option
https://www.sau.com.au/forums/topic/180615-coolant-leak/#findComment-3283758
You basically use CRC or Selleys quick sealant:
There are two types both work fine:
Black one = most commonly used is Windscreen Sealant
Clear one = marine sealant
btoh are silicone, use a 2-3mm strip round the old gasket edges of the waterpump, make sure you scrape off all the old stuff, then put it on, bolt it up and leave it to dry for a few hours :nyaanyaa:
Then it should be as good as new, total cost round $10
https://www.sau.com.au/forums/topic/180615-coolant-leak/#findComment-3283903
Flash if your going to go to the trouble of removing your pump i would install a new item as its a lot of mucking around to get the old one off and new one on.
try just jap they have them in stock as many of the traders here will
https://www.sau.com.au/forums/topic/180615-coolant-leak/#findComment-3283986
its easier to get a new pump, when mine was leaking i asked about seal kits and everyone said to replace the whole thing because the pumps are pretty cheap now a days
if you havn't done your 100k service yet it'll a good time to now aswell considering timing belt might have to be taken off also
dont just seal it up either.. do it properly and change it all
https://www.sau.com.au/forums/topic/180615-coolant-leak/#findComment-3284098
Flash you dont need a gasket you will need to use a silicone based sealant which is applied to the water pump just before you put it in place.
Make sure the surface on the engine block is really clean of old silicone gasket, scrap it with a sharp edge then just before you place the new water pump with silicone gasket applied, give the engine block a spray and wipe with brake cleaner to get rid of any possible oil so the silicone bonds well.
https://www.sau.com.au/forums/topic/180615-coolant-leak/#findComment-3288959
mate i am not sure about a GTS-T but if its anything like a GTR then dont do it unless you are sure of what your doing.
You need to remove the engine vibration dampener of the crank shaft, all the alt, A/C etc. Then you will need to remove the cam timing belt. If you havent done it before get a mate who has or a work shop manual as there i a little bit involved.
https://www.sau.com.au/forums/topic/180615-coolant-leak/#findComment-3289335
ok i just did mine but one prob. there is like a tiny hole in the seal and there is coolant coming out like how water comes out of a water pistol. could i just put a lil dob of sealant to cover it??
https://www.sau.com.au/forums/topic/180615-coolant-leak/#findComment-3294538
    • Nah, they'll do it without a receipt, tell em roughly when it was, that it was cash, youll likely only get store credit, but that gets you some dollars towards the newer better shovel, or other item you need/want later.   Still take it back and have a crack at returning it.
    • Nah. Was just wondering if you were having a small stroke or if there was some slur/gaf/inside joke that I wasn't aware of.
    • That was a fark up, it's Salamanca Place I was thinking of. And now I'm curious as to what potential slur/gaf I have caused with Salamander Road, ha ha!
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
