RB26 Parts for sale 32/33
std injectors and rail $380
std fuel pump $250
Nismo reg $120
chipped computer R32 or R33 $420 (does not run rich like so many of the other ones)
std cams $110
std afm x2 $450
std gearbox less transfer case $400
rear driveshafts perfect condition $380
std sump $110
std turbos good condition (steel wheeled) $450
std exhaust manifolds & dump pipes $250
Sydney Pickup only.
Edited by ZILR
std fuel pump $250
Nismo reg $120
std cams $110
std afm x2 $450
std sump $110
Sydney Pickup only.
prices up
std fuel pump $250
Nismo reg $120
std cams $110
std afm x2 $450
std sump $110
Sydney Pickup only.
air flow mtrs sold
  • 9 months later...
Have u still got the nismo fuel reg?
last post was from august 07.. maybe u should pm him for info dude.. I highly doubt he hasnt sold it in 9months though :bunny:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
