got a few parts lying around that we need to get rid of so here we go.
R32 Bits n Pieces
R32 GTR Wing (black) $100
560kg Engine Stand. Yellow and black $100 (pickup only)
S13 Stuff
5. CA18DET Manual Gearbox Conversion (just missing clutch/flywheel/master cylinder) -$400 {$350 box only}
6. STD S13 Suspension (front and rear dampers and springs) still on car - $100
7. S13 projector headlights with built in yellow foglight - $60
8. S13 Electric Window Control Box (controls all window functions ie auto) [[this is not the window switches]] - $60
9. S13 CA18DET coils. $30 each
10. S13 CA18DE Auto ECU [good for a spare] $10
11. EOI. late model 180 dash with digital odometer airbag model. $400
abs unit off late model 180sx $100
For more info or to buy stuff regarding R32 bits n pieces call Ross [0421 869 037]
To get the S13 stuff call Jimbo on [0405 160 740]
everything is located on north side of brisbane!
Edited by jeffers1987
https://www.sau.com.au/forums/topic/181011-r32s13-sparesmods/
R32 Bits n Pieces
1. Standard Rb20 injectors - $75
2. R32 Fibre Glass Rear Guards - $100
3. Standard Intake Plenum/Runners $100
4. Bilstein dampers and King Springs for front (very low very stiff) $150 (will sell with Gabs for 250)
5. GAB rear adjustable dampers with springs (quite firm) $150 (will sell with bilsteins for 250)
6. R32 GTR Wing (black) $200
7. RB20 Crossover Pipe with STD BOV - $50
8. Highflow RB25 turbo (R34 Compressor) - $500 (still on car available when new turbo goes on)
S13 Stuff
1. JIC Coilovers (6 months old) -$920
2. CA18DE + Auto Box (runs fine - 120rwhp on dyno log dyno) $350
3. CA18DET (in bits) great for rebuild has everything except exhaust manifold/turbo/loom - $200
4. CA18DET ECU - $50
5. CA18DET Manual Gearbox Conversion (just missing clutch/flywheel/master cylinder) - $500
6. STD S13 Suspension (front and rear dampers and springs) good condition - $100
7. S13 2 Eye projector headlights with built in yellow foglight - $100
pm sent regarding hi flo turbo (sold to me pending payment)
Oh prick!! I just saw that and was about to send him a PM.
Congratulations on the buy. PM me if it falls through :D
Free bump :sorcerer:
Thanks,
Abu
Edited by abu
Congratulations on the buy. PM me if it falls through :thumbsup:
Thanks,
Abu
hehe, i was bloody quick , no chance of the sale falling through on my end :D
dump pipe added to the list, damo that cash went in too buddy cheers i will ship the turbo off on monday when i should get a chance to get to aus post. cheers guys
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
