hey guys, just wondering if anyone else has had this problem before, i was racing my car at the drags and had no traction so i ran a 14.6 at 163km/h but anyways when i went to do my 5th run for the day i hit 4th gear and it just didnt wanna rev like it had lost all its power wouldnt gain speed or rev's. and im pretty shore while i was holding threw 3rd it was pinging i could hear a slight taping noise all the way threw 3rd. now i just wanna know why i had no power in 4th?????? it was 1.30pm and probly 30'c max that night i went for a drive and went threw all the gears hard and it didnt miss a beat pulled all the way threw 4th ??????? whats going on
https://www.sau.com.au/forums/topic/181485-no-power-in-4th/
1400r. oh thats very helpful info i didnt think the ecu did that on the skyline never read about it b4 thats all but it makes sence, thanx for your help guys i guess i need to run it on dyno again n get a retune, the last place that did it are a bunch of ................. only went there cause they are the only place in my town with a dyno but i will travel this time
https://www.sau.com.au/forums/topic/181485-no-power-in-4th/#findComment-3297438
the intake sucking closed can be fixed pretty cheap.
search for "intake" by user "rev210"
he had a little article about his simple and effective fix.
also, if you could hear pinging while drag racing, with a helmet... it must have been pinging pretty farking badly..
and it would explain why the ecu woudl retard the timing so you couldn't kill the motor.
I'd definitely have it checked on a dyno to see how the current tune is..
is it tuned?
is there an aftermarket ecu in there?
https://www.sau.com.au/forums/topic/181485-no-power-in-4th/#findComment-3302711
here is the link for the intake mod
http://www.skylinesaustralia.com/forums/in...9&hl=intake
stock ecu and 11 psi and pinging..
where exactly are you?
just go to any dyno place to do a power run and ask to get a print out of your A:F ratio reading.
normally a stock ecu'd R33 goes rich.. if your's is leaning out, it might be a fuel pump/filter/injector issue.
https://www.sau.com.au/forums/topic/181485-no-power-in-4th/#findComment-3303038
5hrs up the coast from brissy Gladstone. . . There is only 1 dyno place in town and they know bugger all. Charged me $60 to clean the T/B when i figured out all they used was a can of T/B CArby cleaner for $6.00
yeah thats not a bad idea, fuel pump/filter/injector. going to do a compression test, then go from there i think.
https://www.sau.com.au/forums/topic/181485-no-power-in-4th/#findComment-3303198
hey guys well i do have a piggy back computer its an safc it is tuned well was about 3 mnths ago so yes i think im up for a retune but dnt want to go anywear hear again. thanx for all the input guys and yeh im not 100% if it was piniging or not but only one way to find out i guess (dyno)
https://www.sau.com.au/forums/topic/181485-no-power-in-4th/#findComment-3303434
GTST, i have a print out and i scaned it but it didnt bring up the numers like on the x and y axis and it wnt upload it for sumreason from wha ti can see it runs approx on 12 till the car hits 120kmh then it dips to 11.5 and slowy rises back up to 12 towards 170kmh, and no there has been no modifications since this tune all i have done is change the oil and its running the same oil just new stuff, it had new plugs gapped at 0.8mm and the mods include fmic/3inch dump pipe/3.5inch cat back, stock cat, apexi safc, pod filter, boost controller set at 11.5psi
https://www.sau.com.au/forums/topic/181485-no-power-in-4th/#findComment-3306256
if it is the intake sucking closed, you can do the mod in the link above.
it will cost you next to nothing.
but the only way to see if it is sucking closed is on a dyno.
or remove bonnet, strap a mate on the front guard, then go for a fang and ask him what he can see.
could be fun.. ;)
https://www.sau.com.au/forums/topic/181485-no-power-in-4th/#findComment-3307137
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
