hey guys, i just bought this gtr fuel pump, but never got around to putting it on, was bought for an upgrade for the car but now i have plans for a different pump so no need for this one, will post pics if asked for,
asking $180 ONO, will post if required...
https://www.sau.com.au/forums/topic/181592-r33-gtr-fuel-pump/
Hi,
Would this be a direct replacement for an R32 GTR, mine could be on the way out i think and what sort of condition is it in - e.g. new or second hand out of a car thats done XX,XXX amount of KMS??
Interested if new...
Many Thanks,
skysaresilver
PM sent!
Hi,
Many Thanks,
skysaresilver
hey guys, can someone buy this pump, send me offers i don't care anymore im sick of it just siting there when it could be on some mad skyline doing its job. PM ME !!!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
