2 day i got a pedders safty check n they said my r33 gtst needed a power steering rack n i was jus wonderen if any1 wuld no how much it wuld coast pedders said it wuld coast 700 fitted wuld dat be a gud price or does ne1 no anywhere where i could get it done cheaper n wat r power steering racks worth ur advice wuld be greatly appreciated thanks?
https://www.sau.com.au/forums/topic/181796-power-steering-rack/
phhfffttt i just sold my spare one for $150 but yeh $700 sounds about what pedders would cost for a re-build
thanks mate i appreciate ur help n do u think it wuld be better 2 get it fixed at pedders or go buy a second hand rack n get my mechanic 2 do it which 1 wuld be cheaper thanks?
theres heaps of good second hand ones out there but you'd have to either trust the person your buying it from or know what your looking for when you look at it, not a hard thing for a mechanic to change over an hour 2 tops but thats a stretch
Hi mate, just wondering re pedders telling you that you need a new steering rack. Do you notice anything wrong with your car?
Such as heavy steering compared to other skylines?
my steering feels normal but i need 2 top up d power steering oil every week or so?
They most likely noticed one of the internal seals was leaking. Make sure the rack boots aren't broken and as long as its not pissing out dont bother replacing it just yet. You can get your one rebuilt. That would probably be the cheapest way. Just call around to p/s shops for a price. If you buy 2nd hand its most likely going to fail in the near future too. Not much point in replacing something old with something just as old. If it were me i would rebuild mine if infact its actually necessary. Keep in mind they are suspension people at pedders and will probably try to up-sell it to you.
Deren
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
