FOR SALE:
ITEM 1: R33 Front Strut brace
CONDITION: Ok, has scratches but does the job
PRICE: $80 ono
ITEM 2: R32 Blitz BOV on Hotpipe
CONDITION: GC
PRICE: $100 ono
ITEM 3: 17" MOMO rims 5x114.3 F: 7.5 3x+ offset, R 8.5 3x+ Offset (perfect for 32-34) as it came on a 34 but Ive used it my 32
CONDITION: Has gutter rashes
EXTRA INFO: Including 6x tyres (4xGoodyear 80% tread 2 with slight camber wear) and 2x Simex (30% tread)
PRICE: $600 ono
ITEM 4: 2x R32 Centre air vents, the bloody rare 1s
CONDITION: In VGC but 1 has 1 vent fin not functional
PRICE: $75 ono
CONTACT: Andy Pm or 0434345424
PICS:
http://www.nissansilvia.com/forums/index.p...p;#entry3472772
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
