I have had this car for just over 18 months and it has never missed a beat. But now I am finished my trade, I need a ute for all my tools.
The modifications I have made to the engine are listed below:
- Blitz crossflow FMIC
- Blitz dual soleniod sequential boost controller (control mounted in drivers sunvisor)
- Blitz turbo timer (mounted in ash tray)
- Precision Turbos Garrett high flow turbo
- New Apex'i Power FC
- Nismo 555cc injectors
- Tomei fuel pump
- Z32 AFM
- Custom exhaust
Interior Modifications are as follows:
- Professionally installed cruise control
- Leatherette seat covers (black with red double stitching)
- Matching gear and handbrake boots as well as centre console cover
- Nismo Leather gear knob
- Red lighting in the footwells when doors are opened
- Carbon Fibre scuff plates
- Full set of dealer specific floormats with red highlights
- An illuminated "Skyline" boot garnish will be incuded
Audio Modifications:
- Alpine headunit with remote
- Rockford Fosgate amplifier with bass adjustment module
- Focal 8" subwoofer in sealed enclosure above fuel tank
- Focal 165K2P Splits in the doors
- Sound deadening throughout entire vehicle (floor, doors etc)
- Brand new Optima Yellowtop battery (best audio/starting battery you can buy)
- UHF CB Radio Scanner/Transciever installed in boot with head unit in centre console (able to scan emergency services freqs)
All of these modifications have been made to look as stock as possible.
The car has been serviced every 5000km using Motul oil and has had the timing belt replaced at 100000km. The car has extremely straight panel work as it has just been in the paintless dent removal shop, there are, however, a few stone chips and a scuff on the front bumper, most of which were on the car when I bought it. Has 130000km on it.
A set of 17" mags with decent tyres are available to the new owner, they were taken off in order to put on the 350z rims.
If you are looking for a well looked after and tastefully modified skyline, this is the one for you.
Contact Leigh on 0409486447 anytime. Pics are here (sorry about the size of the link): http://www.carsales.com.au/used-cars/priva...e|1&trecs=3
https://www.sau.com.au/forums/topic/182201-r33-series-2-manual-silver-cairns/
  • 3 weeks later...
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
