Yeah, not happy Jan. Took it for a flog tonight, all was well then one of the clamps popped off and had to limp it back home. Still have a bit of cutting of my front bar to do also, not heaps, just a touch here and there. Just really can't be effed anymore today, been working on it since 11 :)
  • Replies 241
Posted Images
yea lol. passenger front quarter is f*kd. need a new one. head light was smashed, front bar is fine but scratched up bad, lower control arm bent like banana. I was doin about 100 when it aquaplained....spun instantly 2 or 3 times, there was nothing i could do in the time it happened...just glad that was the only damage and no one was injured.
Looks like I wont make it either unless I can figure out my problems, Went for a cruise last night and all was fine for most of it, But as I left Ingle Farm I couldn't let my rpm go over 2000 otherwise the engine would stall. I have looked for loose hoses but can't see anything may have something to do with the injectors or the turbo as once it starts to boost that is when it splutters and dies!!
Any help would be great
I live in the northern suburbs if anyone wants to come have a look just pm me :)
sorry to hear Ryan i saw you WTB post and though ah no
outcaast check all hoses coming off the plenum and IC piping sounds like air leak im not sure where from though
when i first bought my car it was in for repairs one day and then when i picked it up within 5 mins a hose poped off and did same thing yours is doing
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
