The answer is you can make 200rwkw on the stock unit.
The R34 intercooler is a bolt in and will give you some more headroom for a tad more power. Water spray is not needed at all on the stock turbo unless you have some sustained thrashing involved but, none the less is of benifit to any size intercooler.
  • Replies 41
Posted Images
Why bother wasting $200 for a r34 side mount when you will probably get sick of it/need to upgrade 2-3 months down the track.
Just get a fmic hole cut, get it done by a pro, make it look nice n pro. Dont worry about cutting a hole, we all do it but if u have a spare 1k go do what some ppl here mentioned.
The way i see it, cooler kit for $350 (i have one ready to go) installation ~100-150 u just saved 500-600 on other mods that u will enjoy
$200 on an R34 intercooler is very little money and still cheaper than a fmic, on a stock turbo or hiflow with power levels upto 220rwkw or so.
So you can ask "why spend another $300 for cop bait, extra weight and more often than not, no extra performance?"
Then again be a bolt on boy and follow the sheep? Who cares it's all good.
hmm rohan is that you from ns.com?
or how do you know my name lol?
umm yea he bought it from ebay..
Theres another one on sau for 100 bucks.. guy lives in penrith area i think
I also have sourced one out for 120 bucks in melb..
Paint it black, you will notice the difference of a FMIC on the track.
Follow the sheep? wtf..
People use FMIC kits because they work. $200 for a side mount, and for $130 extra you can get a FMIC kit which will do a the same job, and will support more than 200rwkw if you do chooses to go there later.
I mean he has an Rb25, all he is has to do is boost it to 13psi or so, with exhaust adn shit, and that side mount becomes useless as he will make over 200rwkw anyways.
Why would you bother going a sidemount? I know I wouldnt.
He will put the side mount in, boost it to 13psi, get about 200rwkw, drive it hard, either on street or track and the thing will suck, then he will want more power and he will have to rip the side mount out, and spend another $300odd and get a FMIC, when he should have just bought one in the first place.
Honestly, with prices of FMIC kits now, why would you bother with a side mount?
Edited by abu
Meh no point arguing with these ppl abu.
Just state your opinion and let them decide.
Stiff shit if they don't want to listen.
Tell me about it.
It's like a temporary solution. No Point!
Ah well. Good luck with it all.
Thanks,
Abu
Edited by abu
A few guys I know have run low 13 and even high 12s with a standard R33 intercooler. Not R34 upgrades, on the stock turbo. Doesn't seem that useless to me?
The r34 core is proven to flow efficiently to 220rwkw, so you can make over 200rwkw if you like.
My last R34 intercooler cost me $80.
man i love ur car
looks so fkn mint, i wish my 32 looked as pretty as urs :glare:
where to get a gtr bar in melb?
Hahah thanks man. Your car is tough as!!
Did you do the RB25 conversion your self?
GTR bar came on the car from Japannnn :P
Sorry to go off topic..
High 12's? On stock cooler?.. :glare:
$80 straight bolt on hey, pretty good man.
Included all the piping, clamps and joiners too?
Edited by abu
ive got an r34 cooler on mine. only seeing about 190rwkw @ ~10psi. its doing its job fine. but now i want to get it tuned to 12psi, with a new exhaust setup. i'm thinking it will be safer with an fmic. so yeah r34 is kinda temporary. but it was a piss easy swap over, and pretty cheap.
If you are running a stock turbo or anything under 220rwkw (bonnet down) then there is no 'safety issue'. :glare:
this seems to have turned into the battle of the fmic vs the r34 coolers. ah well its always worth a read. I am about to source a r34 cooler for $50 all up. I think its a decent buy. Will let you guys know how I go after a tune.
hahah you stalker.. but howd you get my name anywyas?
umm see you found one for 50..
I see some ppl selling 34 coolers for like 200 plus.. im like wow!!
What's the difference between R33 stock cooler and R34 stock cooler?
Just curious on why these are soooo goood.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
