hey all,
wanting more response / power from the 33 and cant decide what would be a better option.
im pretty much leaning toward a ebc ... but would like a few ideas from others.
its pretty much standard apart from exhaust and panel filter , just getting to used to the power.
also have a t04 here i want to use, but dont have the funds to get that installed.
cheers
shannon
https://www.sau.com.au/forums/topic/18248-safc-or-ebc/
yes, EBC first.. you will be able to wind the boost up a bit and get a fair bit more power before the stock ECU settings will tend to lean out.
Other option is a cheaper bleed valve ($100 ?) to set your boost a bit higher and then S-AFC to tune up for more power. You could probably get to around 150-160rwkw then before you needed to get a FMIC.
https://www.sau.com.au/forums/topic/18248-safc-or-ebc/#findComment-380853
ok so looks like the bleed valve and safc might be the way to go for now :P
any recomendations on which bleed to go for? from what i can see the 2 decent ones are the gfb and the TurboXS HPBC . also if i am to get one of these and install it, do i then need to buy a boost gauge so i can see what its actauuly boosting to.
if so, wouldnt it be cheaper / roughly the same to get an ebc ?
sorry, im dumb!
shannon
https://www.sau.com.au/forums/topic/18248-safc-or-ebc/#findComment-381093
Hey Shannon
I had the same dilema as you before, whether to purchase a bleed valve or an elect boost controller.
There is heaps of advantages of the ebc over a bleed valve, but due do to money reason I had to settle for the Turbosmart single stage, it allows me to flick from standard boost to high boost from inside the car. The unit cost me about $200 and i have been told you do need an accurate boost gauge when installing one of these. So rougly eveything came to $400 not including installation.
Now when boost is set on high, it comes on more quicker and it sounds MAD!!
The only worry i have with the bleed valve is that I'm scare it will overboost. So now days when i'm pushing it, i tend to be more focused on the boost gauge than on the road haha. I guess that's one of the main disadvantages of a bleed valve compare to a ebc. Alot of them have some sort of safety function for boost spike or overboosting.
I also intalled a A/F ratio meter to check for leaning out. And with boost set at 11psi there seem to be no problem. Still running rich actually. So my next step will be either the SAF-C2 or a piggy back comp.
There are some cheap second ebc on ebay sometime. That might be an option. The cheapest ebc I have seen is properly the profec-B and now GReddy just realease a new model too.
https://www.sau.com.au/forums/topic/18248-safc-or-ebc/#findComment-381237
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
