Hey guys
I’m looking at buying a mate’s skyline r33 .he basically just wants to get rid of it now after having a kid and needs to settle down. He has put a lot of work into it and its making 300rwkw .my only problem with buy the car is fuel economy.Next year I will be working full time, which means I will have to drive a lot more.
The o2 sensor (the one used for regulating fuel for constant driving like on the freeway) is broken (I have been told it’s a $50 job) so he can’t give me an accurate number; at the moment it’s doing about 200ks to a tank. Does that sound about right? How much do you get from a tank? What should I get a tank? If I run the boost at about 7psi daily what kind of economy should i expect?
Modifications:
Bigger turbo (td06 25g) running 1.2bar max
Intercooler
New ecu
Hks mid lift cams
Upgraded fuel pump and injectors
Exhaust
Thanks
https://www.sau.com.au/forums/topic/182500-expected-fuel-economy/
Ooo tough choice ey, if your THAT worried about fuel economy then you might have problems because you either
A: wont enjoy it to its full potential or B: will go broke buying fuel every second station.
Would I be right in assuming that with a new o2 sensor you should expect no more than around 250-300ks to a tank...maybe a tad more
if you drop the boost...also depends on the tune?
my car origanally made 500kms to a tank until i had a new ecu placed in my car it now makes around 300km a tank on a good day the problem is the tune which is being fixed at the moment by another tuner who knows what there doing and have it tuned for economy, 300kw is great but you will start to hate your car when you see that fuel bill
If you worried about fuel economy, then thats definetly not a car for you. I dont know if I was looking at a daily driver I doubt id be getting a skyline except for the V35 since its pretty comfy lol.
Sorry a bit off topic, but is that your car in your sig? Damn that looks sweet :P
or if your super keen on the car and its a once in a lifetime opportunity.. buy a bunky to get you around during the week and keep it as a weekend car?
to be honest even changing the o2 sensor wont make it a super fuel efficient car.. I Think juts about any straight six turbo motor driven with some enthusiasm is going to drink the juice
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
