Power FC is L-jetro (afm ) model is virtually brand new and comes with matching FC Commander (hand controller)
Power FC PRO has the two-step rev limiter / launch control function featuring ignition cut instead of fuel cut like most "normal" Power FC's
The "PRO" is no longer available and is a highly sought after item.
Z32 AFM's have had a couple of hours dyno time and travelled 800mtrs (two drag passes) if you include the return road and pit entry and exit 2000mtrs.
Bee-R revlimiter is in as new condition and is a good mate for a regular Power FC that does not have ignition cut function.
**********PRICE's*****************
Power FC and hand controller $800
Power FC PRO $1300
Z32 AFM's $220 ea
Bee-R revlimiter SOLD
*******FIRM NO OFFERS*************
*********ATTN ALL ITEMS LEFT ARE ON HOLD DUE THEM BEING REQUIRED TILL THE END OF NEXT WEEK 14 SEPT********
can you post the model/part # thanks.
its in the car at Croydon Racing so i don't have access to it right now but...
its a 2004 model from memory and is compatible with the current Excel laptop software (unlike earlier models)
its been the ecu in our race car and would not even have 20hrs clocked up on it (zero road use, track and dyno only)
only selling due to upgrade to Autronic SM4
mate ur pm inbox is full apparently.
any idea on postage for Bee-R limiter to QLD 4563?
Thanks
Jamie
Edited by «Cyph3r»
Thanks
Jamie
ill post it to ya for a lazy 10er
been away for a while and PM's have been busy..cleared a few out so PM your delivery address and ill forward some banking details
do the AFM's come with plugs?
And will it fit in a R34 GTT?
no plugs...not at that price $250 with new plug plus freight
im interested in one afm.. will u take $200 mate?
thanks chris
$220 plus freight..i did say the prices are firm.
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
