Hi
My parents recently bought an r34
it has a hornet alarm system, which them nor i know how to operate
apparently its a 717m or a 718m or a 719m.
The remote has to buttons the first has a number one on it the other, number 2
any ideas?
Thanks in advance
https://www.sau.com.au/forums/topic/183199-hornet-717m-or-718m-or-719m/
ok do this:
split the remote open take a snap of the internals front & back - from there I'll get you a proper users guide and service manual for it.
no offence but how will that help?
are they similar to the viper alarms of something
will do shortly
Edited by R32_R34
remote as requested
By r32_r34, shot with < Digimax U-CA 5, Kenox U-CA 5 / Kenox U-CA 50 > at 2007-09-03
ok. 717. pm me an email addy and I'll send you what I have.
button one arms / disarms.
now if the red light is on it is in valet. under the dash you will see a pushbutton switch. hold that in turn the key on and release. light should go out. turn key off , remove, close car, press button should get a chirp. now if you are relying on that for security and insunace - run with your idea.
for some reason hotmail does not like me.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
