WILL SELL CHEAPER WITHOUT WHEELS AND OR WITHOUT COMPUTER
As per my PM (which you never replied to), I would consider buying the wheels if you'd separate.
That might help with your sale, PM me if you want to sell.
Good luck with your sale.
Cheers,
Chris
do you mind sharing what shop you sourced your rims from?. they are hot as. and i would love a set for my 34
cant believe you cant get 13 grand for it dude!
Edited by Granthem
real nice guy you are!! clutch adjusted, torn drivers seat BIG DEAL, cracks in the paint??????? i spent 3 grand gettin the body into great nick, with only blemishes in the front bar, from genral wear and tear!!!!! DONT COME HERE AND START TALKIN CRAP!! GROW UP MATE!
Not trying to start anything.. just thought u should mention it has the torn seat etc.. car looks good yea front bars no good but thats easy to fix. Look on the left front pillar paints cracked.
  • 4 weeks later...
  • 2 months later...
    • THERE IS NO IAT SENSOR ON ANY SINGLE TURBO RB. And the one on an RB26 is not for "engine control" - it's really too big and too slow and is only used for over-temp alarming (as far as I can tell). Anyway, you don't have one. You want/need one for the Link, then you need to buy one, find a spot for it, and wire it in. You do know that the stock boost solenoid is not capable of "control", right? It is merely on or off, for the low boost (5 psi) and high boost (7psi), which the ECU enforces mostly based on gear. The stock solenoid is not for PWM control and is not plumbed up in a way to provide it. If you want to control boost properly, then you need a proper MAC valve. And yes, you can wire either of them direct to the ECU. Well, I assume you can - I don't know what the boost solenoid pins on the plug and play Link are capable of. They really should be as capable as any normal Link - but seeing as it is plg and play, it might be limited to stock functionality. Read the doco.   You really do just want to plug stuff together without understanding how it works, right? I can't help you there. I don't know the plug types or pinning on half the stuff you're asking about. If I had to do it I would sit down with the wiring diagrams, the car/looms and a multimeter and work out what is what.
    • Light should be a pressure switch, not a sensor.
    • The pressure light likely has a different sender to a pressure gauge, its been too long for me to remember for sure. Just have a look for another sender down near the oil filter. If you are confident in your rewired pressure sender reading correctly, you can be pretty sure it is just the dash light's sender failing, it is a pretty common thing.
    • It would be nice to see the result, but instagram is a click too far
    • That is a series 1 front end (grill, bumper, headlights). I'm not sure if you are trying to confirm if your whole car is series 1 or just the headlights, but the build date and vin# on the plaque in the engine bay would be the best reference for what it was when it left the factory (noting a lot may have changed over the years)
