Hi guys..
well i just installed a 2nd hand (30,000kms) Cusco 2way LSD into my 180sx.. i opened the filler plug and checked the insides for oil.. was green and clear. so i plugged her up and installed her. took for a lil drive and its chirping the wheels and very tight.. drove it a bit more and then it made a clunky noise sometimes.. then took on highway at 0-100kph its quiet. then 110 if i accel it makes a slight whine. then settles after 115kph or i back off.. very faint lil whine..
my questions are.
1. what is that clunky noise.. how bad is it.?
2. any idea what that whine could be at 110kph..? and only under accel.
3. what oil do you recommend to service the diff with.. eg. redline shockproof 85w-140?
anything else i should knw about the cusco.?
thanks
mark.
https://www.sau.com.au/forums/topic/183346-2way-cusco-lsd/
Mate its normal these diff's are design to lock up the whole time they are a savage diff designed for drifting and drag racing. they are not meant to be used on the street as in the wet when u are wanting to drive round a corner you car may decide to keep going straight or decide to do a full 360. these diffs also require a very good diff oil to keep them in good order.
https://www.sau.com.au/forums/topic/183346-2way-cusco-lsd/#findComment-3323135
thanks a bunch guys..
was recommended by a mate to use 80w-140 penrite that or castrol full synthetic 80w-140 any thoughts..??
diff has no oil in it at the moment.. just doing a service on it and just deciding on oil. budget is no issue really.. realistically
https://www.sau.com.au/forums/topic/183346-2way-cusco-lsd/#findComment-3323699
my nismo uses an 80w-90. It may be worth checking with a cusco supplier about what oil is best for your diff. It's also worth confirming the type of diff as there is an MZ and RS (i think) from memory, and they are different designs.
Other than that, sounds fairly normal, though the whine isn't a good sign. Do you know if the back lash was set properly when the center was installed?
https://www.sau.com.au/forums/topic/183346-2way-cusco-lsd/#findComment-3325308
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
