Guys Girls .. ..InBetweens .. (yes we all know who that is) .. Resident Drug dealers... Tuna Stains..Cat Rapers..
Anyways to the point...ITs ON AGAIN !
Date : - 7th Sept 6.30pm - Late (or till coffee club shuts)
Where? : See Map (Usual Spot)
Put Ur hands Up Kids If U Wanna Come ! :D
Plan is - Meet For Coffee .. Slowly after consuming ever so many spicy chai .. move out to a cruise around the city ..
Someones already said no pics or ban lol.. so we shall give them some pics to stare at weather its the inbetweens doing their thing or the dealer making a deal.. :worship: or the tuna stain lady giving adam some stain loving.. :(
Weather id be Adam doing it CAT Stylz...( im assuming his kids will love SAU) ..
Edited by 53XYN
https://www.sau.com.au/forums/topic/183444-coffee-chai-meet/
  • Replies 74
Posted Images
Me and the other half shall be there as usual!!!
I think i'm gonna have to go with the "Mr Scratch and Sniff" nickname for Adam now.. The cat stylz was soooo three coffee meets ago... hehehe. I'm sure Mr Scratch and Sniff will be up for a sampling of the tuna Vishy....
Do we all know who the in-between(s) is????
Miss out the last one and can't go for this one..since i'm not in brissy this weekend.. :)
Will definitely go for the next one.. wana share with u all about DIY ur third brake lights with ultra bright LED (1000mcd) for only less than $60 :)
Never too late we didnt leave till 1015 last time hehe
yea u stayed even after those bitches took our wind barrier, u hardcore dude lol.
with all those chick put up with every week i rekon they shud sponser us.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
