I am in putting a new motor in my car and the RB20 that is in it will be available in 2 weeks.
the engine has done less than 100,000 k. it was put in the car when it had 48,000 and has done 50,000 since then. The timing belt, water pump, idler and tensioner have been replaced. the engine is currently making 230rwkw and is in excellent condition.
As it is coming out for a conversion it will not be complete but would suit someone with a blown RB20 that wants a good condition drop in motor. it will be complete head and block with no ancilleries.
$400
Also have a blitz super sound BOV in excellent condition, it is fitted to an R32 factory pipe and I would need the unmodified pipe in exchange.
$100
Also have PBR organic full face clutch with pressure plate and flywheel. I have no idea how many k's it has done but it is mint! excellent brand clutch that will hold +200rwkw looks like it has done less than 200,000 k's
$100
All items located in Canberra but freight can be organised :nyaanyaa:
sill all here. anyone? please don't tell me I need to buy a datto 120y to drop this all into :)
don't think I won't do it!!!!
Nic, the clutch your selling is that the same one thats running in the car at the moment, holding 230rwkw?
Also, how much meat left on it, or is it near new condition?
If you were in Melbourne man, I wouldn't mind grabbing that motor for a spare one to build up..
Freight to Melbourne? ;)
Thanks,
Abu
Edited by abu
Thanks,
Abu
Hey Abu ;)
the clutch is in excellent condition. it was actually on an RB30 but is the same as an RB25 heavy duty clutch. I can get some pics for you. its a PBR :) and they dont make crap
The engine would cost about $100 to freight.
I am coming to melbourne on wed and thurs so might be able to bring the clutch for you?
Hey Abu ;)
Good stuff.
Writing up a PM for you now Nic.
Abu
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
