Cant say that tells anybody much. You could have got the same shot out of an IXUS. The 40D has some nice features, but I can't warrant an upgrade from my 30D. :)
I can't say I really would either from a 30D, I upgraded from a 20D.
Basically yeah I was just saying I got a 40D and yeah its awesome!! haha ;)
https://www.sau.com.au/forums/topic/184116-canon-40d/#findComment-3337185
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
