Yes that helps, thank you. Is the E-Manage fine? I dont know the price for the SAFC but the E-Manage is pretty cheap. Where would I get Auto Shift kits from as well as a high stall converter? Which brand of boost controller would you recommend?
Thanks
Help
A TURBOTECH bleed valve is fine, costs you about $30 or so. Proven to work very well.
http://www.skylinesaustralia.com/forums/in...amp;hl=$22
SAFC II is made by APEXi and is a fuel only computer, roughly about $250 - $300. This is fuel only and doesn't support after market injectors so dont think it will be ideal for you.
E-MANAGE is a good little unit, again dont know much about it or the price, but do a search and you will find heaps of stuff about it.
REMAP will probably be cheaper, so if you get everything done at once, then just take it in for a tune and leave it.
See how you go though.
Edited by abu
Ok Thank you, will start buying parts now. I checked on Just Jap and they have a 570cfm hi flow cat for only 200 dollars. I am going to get that and the front pipe and will do the first mods.
I will let everyone know how it comes out.
Thank you everyone
As a rb20 owner myself, and having worked my way through my fair share of mods i have found that sometimes the simplest things make more improvment than you would think.
From stock I added:
Cheap chinese t04e
highmount manifold
12psi
Cheap FMIC
about $1100 all up
Made 170kw or just under 230hp
From there i added:
BOSCH 040 fuel pump
GTR injectors
Apexi AVCR 14.7psi (1 bar)
Full turbo back exhaust custom front pipe and dump pipe and trust stainless exhaust
Highflow cat
Garrett GT2876R
Low mount manifold
Microtech LT12S
About $5500 all up
I then dynod it at 228kw or 306hp
But now i have taken sort of a weird step some might say and buying a rb24 comprised of a rb20, using rb26 crank and rods
Some of its goodies are:
Garrett GT3076R
Stainless highmount manifold
Custom Dump pipe
Adaptronic ECU
SARD 650cc injectors
JUN 272 cams
HKS cam gears
Forged Eagle H-Beam rods
Custom ROSS pistons
TRUST 1.5mm headgasket
Ported and polished head
Custom made and designed intake plenum
HKS oilcooler
HKS tripple plate clutch
ACL race series bearings
Around the $10,000 mark so far
Looking for 500hp plus on 25psi
So its all about what your goal is and how much money you want to spend. Its best to start with the small things and you will picup and learn what aspects make more difference thanothers and sometimes the really expensive items make less of a difference than the cheaper ones.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
