Yeah like mentioned closed where hole in the road is... i used this arvo to get home from erina and i get on f3 at gosford and get off at the first exit can't remember what its called but its the one straight after you up the huge hill lol.
But lots of pol pol patrolling it now, even during the week i've seen a few... today was nuts sore like 3 cop motorcycles and 2 hwy patrol - spose with the f3 being a stand still they had nothing better to do.
https://www.sau.com.au/forums/topic/184274-oldpac/#findComment-3337050
I still think they should turn it into a one way touge course and charge a fee per run. I'd pay $10 a run to belt up the Old Pac at full steam! ;)
If only......
The locals would bitch and moan if you did that, even if you cut them in on the fee. They were probably the biggest force behind getting Race to the Pie cancelled, even though there's no houses on that hillclimb between Mooney and Pie in the Sky.
https://www.sau.com.au/forums/topic/184274-oldpac/#findComment-3339719
If only......
Yep they like to bitch, my dad rides the ol pac on his bike all the time and last school hols (hes a TAFE teacher) he got pulled over 5 times in 3 days for random "rbts" - the locals apparantly don't like the noise of bikes too early in the morning ;) .... although late Monday & Tuesday nights is good for a clear run.... not speeding of course :)
Seems much easier these days to do Spencer and wisemans rd :D
https://www.sau.com.au/forums/topic/184274-oldpac/#findComment-3339886
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
