hi, i purchased a rb25 ( turbo) long block for my car about 6 months ago unsure of whether it was a s1 or s2 engine.. i only recently finished installing it into my car.. today i went to start it and it wouldnt start.. now my original engien in the car was a s1 so i plugged everything off my s1 engine onto this new engine.. i have some doubts that it could be a s2 engine because the coil pack cover was slightly different at the back to the one that was on my s1 engine. now if the engine was a s2 engien would assecories come on if i put the key in? i'm going to change the battery tomorrow to see if that is the problem but i would like your thoughts on the matter..
thanks
https://www.sau.com.au/forums/topic/184678-need-help-engien-not-starting/
no fuel pump priming and no starter motor going..
Yeah just double check everything battery, earths, connectors etc. You should still be able to see the dash lights when you put the key in. Can you hear the starter motor going or the fuel pump priming? or is just totally dead?
ok i bought a new battery and installed it... i checked thoroughly to see if everything was plugged in and found that the earth cable wasnt mounted onto the engine.. I put it to accessories, the fuel pump primed this time. i go to start it and the started motor makes a noise once and then all the dash lights go off and have to disconnect the battery n put it back on to attempt again and still the same thing happens.. any ideas.. also checked all fuses.. all ok
there is good metal to metal contact and also the battery terminal is screwed on tight.. what i'm worried about is that it could be a series 2 engine and i've hooked up s1 ecu and s1 ingnitor module to the s1 coilpacks. But if it was a s2 engine would it be priming the fuel pump if it has the wrong ecu in it?
The engine doesn't mean anything
If you have a Series 1 ECU, loom, Ignotor pack, and coil packs, then it will be fine.
You might have to think outside the square. Grab a multimeter and go to town!
Tried a different ECU?
i havent tried a different ecu, however all the sensors and ecu and loom were all workin on the other engine. the only thing that i can think ov would b that i have a series 2 engine with s1 components on it. also i wouldnt know where to start with the multimeter ( never used one before)
mate, the Head and block in the Series one and two would have no differences.
Only the wiring loom \ ecu \ coil packs etc. So you've effectively downgraded the entire ignition system down to a series one, which will be fine. So a Series Two engine and head with a series one ignitor pack, wiring loom, ECU and coil packs would work fine..
Unless the wiring in the rest of the car to the fuel pump or something is different?
if you go back to one of his earlier post he says
the fact that you have a series 2 motor being controlled by a series 1 loom doesn't have anything to do with it. you swapped everything over. didn't you?
have you checked your connections to the starter motor?
its abit worrying when you say you wouldn't know where to start with a multimeter and your attempting to fault find a clearly electrical fault. i'm not having a go at you, everyone has to start learning somewhere.
to me it sounds like you haven't got enough power going to the starter. bad connection somewhere? altenator to starter motor connection?
nah nothing else is different.. i'll give it another check over tonight when i get round to it and post results.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
