Apple Ipod 30gb - White - 5th Gen - Used Very Good Conidition
Apple Ipod White 30GB
Used - Very Good Condition - GENUINE
100% Positive Rating
Hi, I am selling my apple ipod 30GB which has been rarely used and lives in cases all of its life. It also has has had a screen protector on since I purchased it from David Jones in Newcastle. I am selling as I barely ever use it. It will come with all the accessories shown in the pictures (although I would rather keep my earphones as sharing earwax is kind of.......icky)
Includes:
1. Ipod 30GB with fully charged battery
2. USB 2.0 Cable
3. iTunes for PC and Mac
4. Clear/White Silicon case
5. White sleeve for ipod
6. Screen protector (has been on ipod since purchased)
7. Black aluminium hard case with spongy cushioning
8. All Apple Documents and ORIGINAL apple ipod box
THAT MEANS YOU GET 3 CASES!!!
The ipod is working perfectly plays videos, games, music etc.
Ipod has just ran out of warranty sorry.
Will post anywhere in Australia via TNT Couriers and overseas.
Please do not bid unless you are serious about the item as I have worked hard for my 100% Positive Rating
NOTE: In the pictures there seems to be a purple scratch (in the middle of all the picture) although this is just my crappy camera. sorry.
Make An Offer - OR
FOR SALE ON EBAY: (starting Sunday 16th September 20:00)
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...C:IT&ih=004
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
