Hey all,
I just managed to get my hands on a 87 200ZR Fairlady.... There are few things that I want to do to it and I need an idea as to what other cars I can get body parts etc off... There isn't alot of info out there on these!
Engine is easy - RB20DET.. eventually it will be RB25 or RB26 :P
Gearbox - also R32
Drive train??? Possibly R32 tailshaft? It runs the R200 diff and thats in good nick so Im not concerned about that!
Body...hmmm... its classed as a Z31 so I am hoping Z31 300ZX... Dave (T04GTR) mentioned that DR30 are interchangable as well.... does anyone have any other ideas?
Cheers,
Anna
https://www.sau.com.au/forums/topic/184739-200zr/
  • 4 months later...
Heya
Ive got a Nissan 200ZR (87) as well. Its the same body as tha Aussie delivered Series 3 300ZX (commonly called the Californian). Trying to get hold of as many people with same cars to help with parts too. Been trying to locate front parkers (as mine are Amber) that are clear/amber from S3 300zx. Drivetrain is pretty easy to source parts for. A lot of Skyline gear is Interchangable. Drop me a PM if you need some parts. Will try keep look at for them and hopefully you can do same.
cheers
https://www.sau.com.au/forums/topic/184739-200zr/#findComment-3584158
  • 1 month later...
Yeah the 200ZR is a fantastic little car, good to see another one out there. If you want any info about them, I know a fair bit about the RB20 redtops, and the Z31/R31 series in general (as heaps of parts are interchangable between the two) also have owned pretty much all the variants of the Z31/R31 series at some stage.
https://www.sau.com.au/forums/topic/184739-200zr/#findComment-3727372
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
    • Isn't there a PAR engineering gearset that has closer to stock ratios? And they claim they'll do whatever ratios you want.
