I've got lots of stock bits to get rid of.
Big discounts if pickup/multiple purchases.
Some items will be given free with another item purchased if you pay postage.
Stock R32 stuff
Gtst rims X 4 (the usual marks but tidy enough) $150
Set of Stock wheelnuts $10
Sedan boot spoiler (leds working, needs respray) $40
Motorised front bar lip spoiler $30
All 4 sedan doors / glass / power window regulators etc $150 the lot
Gtst stock catback exhaust vgc $80
TypeM 4 spot brake calipers (suit rebuild) $80 pr.
5speed auto trans. $50
Driveplate and torque converter. Free
Auto Driveshaft (in bits) Free
Auto shifter Free
Auto brake pedal assembly $10
'89 gtst lhs guard liner $20
Gtst intercooler x 2 +some piping $20 ea.
Used Coils x 6 $10 ea. $30 the lot
4 stud hub and knuckle assembly left and right $50
Non turbo brake discs and calipers $30 pr.
front struts $50
Rear struts/springs (no tophats) $25
Front swaybar $20
front upper control arms (need rebush) $10 ea.
Rb20/det engine and transmission mounts $10ea
'89 foglights $40 pr.
'92 foglights (no surrounds) $20 pr.
Clear indicators (broken brackets, no bulb harness, repairable) $20 pr
Bonnet liner $20
Non turbo exhaust manifold $20
Manifold heatsheild (vgc) $20
front speaker baffles $10 ea
front speaker grilles $10 ea
glovebox lid $20
lower dash panel with fuse cover $15
instrument cluster surround (auto) $20
Centre dash console (main body) $20
Misc. parts
Rb30 motor (no camshaft, suit conversion) $50
R31 airbox lower half Free
R30 front bar cover, reo and filler $40
Marathon 2.25" stainless round tri-flow muffler $20
Genie turbo 2.25" stainless oval muffler/resonator $20
Finer filter pod $10
Crane cams XR700 ignition module $20
All item located NSW far north coast.
Bring a trailer and take the lot for $300.
Also R32 cusco pillowball castor rod (one only vgc) $100 or I'll buy yours to make a pair
  • 1 year later...
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
