  • Replies 58
cool, I'll add you tonight mate. I did add the other guys too but they haven't accepted yet? quandons etc. just check your clans area and there should be an invite there. :thumbsup:
god it will be nice to actually play a team game and work as a team. getting sick of being killed by knuckle heads on my own team and basically just having people off doing their own random thing. espcially in the TDM you really need to team up with at least 2 guys (but 3 or 4 is better) then go pick off the enemy as you usually can get them alone or 2 together. same goes for CTF and ZNS too I guess.
https://www.sau.com.au/forums/topic/185133-warhawk/page/3/#findComment-3459779
  • 2 months later...
Hey Bear Baron I just got this game and would also like to join your clan my PSN is Smurf80 let me know when you have added me and ill jump on. Ive played it twice now and are starting to get the hang of it. Talk about a steep learning curve!!!
https://www.sau.com.au/forums/topic/185133-warhawk/page/3/#findComment-3605262
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
