i did manage to get myself into some better places, but it was all at about 4 and 5am. was good no crowds to stop us having a good look while on the job.
saw a few boobies too
the fella that did msg me, did you end up making it in?
https://www.sau.com.au/forums/topic/185591-gc-indy/page/2/#findComment-3424777
secret squirrel stuff. haha naw its not secret we were making sure that nobody was trying to ruin everyones day by putting bombs or stuff like that around the place. there was heaps of things happening early in the morning waaayy more then i expected.
https://www.sau.com.au/forums/topic/185591-gc-indy/page/2/#findComment-3424829
neither haha truth be told I'm a scum Uni student but I'm also Army Reserve, was on part of the track and around the pits abit. I only did search sat night/sun morning the other days i was not really anywhere near the track was off doing other stuff. was cool i got myself an event staff shirt without doing much at all haha
https://www.sau.com.au/forums/topic/185591-gc-indy/page/2/#findComment-3424847
Well it was a great weekend of motorsport, it was tained for me however as a close friend and customer of mine died in the early hours of Saturday morning.
So i got me thinking lifes too short, didnt sleep much as I could not stop thinking about him for most of the weekend. But all in all it was nice weather.
https://www.sau.com.au/forums/topic/185591-gc-indy/page/2/#findComment-3424907
:D I'm really sorry to hear that Col. What happened? (if you want to share)
well I had a good day with Anna (msnismo) & Dave (T04GTR)...alomaholic slushies rock, and I saw boobs before I even got thru the gates LOL
in Brissy till Thursday so if there's a dinner or anything let me know!
https://www.sau.com.au/forums/topic/185591-gc-indy/page/2/#findComment-3425422
Any female would have :D
Sorry to hear about the loss.
Oh yeah, there were heaps of Army Reserves there.
Few Pilots there too.
Do you guys have access to anywhere?
The male and female pilots did i think, no passes no nothing and walked into our grandstand/corp box.
https://www.sau.com.au/forums/topic/185591-gc-indy/page/2/#findComment-3425539
score!!!!
PM me if you want the details for dinner on tuesday night!
https://www.sau.com.au/forums/topic/185591-gc-indy/page/2/#findComment-3425609
