Hi All,
I am selling my GTST as I have lost my licence for 9 months for dragging off a VN-SS in town :S (first offence)
Its still on JDS from when I brought it :S
http://www.jds-auto-imports.com/car_displa...;pagetype=STOCK
Since I brought it from JDS I have done these things:
Front bumper was damaged so I replaced with a 400R bumper <looks NICE!!!
Front Mount Intercooler
SAFCII
Exidy Sports Organic clutch from Slide (Clutch died 2 days after I brought the car)
Tires where bawled on the back so I put a set of Potenzas on there (75% tread)
RB20DET actuator
nice new stearing wheel
fixed fuel cutting issues
This car goes very hard... I havn't had a chance to put it on dyno but with my SAFC tune(Yes its safe I checked Air fuel mixtures) this thing is maxing the AFM without even trying. (Maxing AFM just means that the AFM is reading max air, so any air that comes in above the 100% reading makes it run leaner but I tuned SAFC to richen it up when the AFM maxes under full throttle to fix this) I would recommend a Z32/Q45 AFM though to get the full potentual out of this car. I would assume 200RWKW because thats around what the AFM maxes at.
$14000 ono.
Edited by Finny
https://www.sau.com.au/forums/topic/185658-fs-r33-gtst-4door-black/
I put an RB20DET actuator on it because they are a 10PSI actuator so the spring is stronger. this means that the exhaust pressure can't push the wastegate open so it boosts quicker. I have the RB25DET actuator still and it works fine.
I am not sure about the duty cycle as the SAFC doesn't display this but I would assume it would be around 70% as 370cc x 6 injectors should be good for around 240-250RWKW and if I am making about 180-200RWKW then that would be around 70% so there would be a fair bit of head room there.
These are only estimates though but I can say this the amount of oxygen is proportional to the amount of power, obviously cold air is more dense so more oxygen so more power. My mates R34 GTT AUTO pulled 172RWKW and his car hits about 96% AirFlow at that and he has a side mount intercooler so going from this my car is hitting 100% AirFlow at about 6000rpm and continues to pull hard to 7000rpm and I have a FMIC so colder air. I would assume that mine is making around 190ISH RWKW from this info.. Altough consumptions mean nothing so I can't really say how much power it has all I can say is its very very satisfying to drive especially when VVTI kicks in at 5000rpm :P
ALSO this car has a 4.39:1 diff gears so its a little shorter geared than your average manual.
The reson i asked is because i have just had my car tuned and it's putting out 214kw @ 10psi, but apparently my airflow meter still has plenty of flow in it. but it's the injectors that are running at 100% duty cycle.
Hey David,
If your injectors are maxing out, run a FPR to get more out of them.
Thats bezzar I have seen people run 250+ RWKW off stock injectors, as he said get a fuel pressure regulator and wind some more pressure in there and get a re-tune as more pressure will prolly make it run rich.
sorry to butt in on the post, but guesty, dont you already have an adjustable FPR hooked up? and g/l with the sale finny
Edit: already answered the question above
Edited by madaz R33
I am not to fussed about selling it as I do really really like this car but I don't see the point of it sitting here for 9 months doing nothing..
Also a mate drove it the othernight.... at 80km/h a cat jumped out in front of it and snapped the front bar pritty much clean in half... ARG!!! fibreglass sucks.. ohh well the cat is dead atleast.
So I go to get a new front bar for it and get it sprayed up.
No damage what so ever to the front bar except there is a bit of cat fur on it :thumbsup:
I am considering doing an engine overhaul, new turbo, PFC etc. if I was to keep the car.
Let me get a new bar ready etc then I will post back with photos and you can come and see it.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
