hey there... hope someone can shed light on this problem...
had a bit of a race the other night and after i backed off the car just all of a sudden lost power and spluttered under boost... it had done this on a couple of occasions before this but all i did was turn the car off and back on and the problem went away...
it also is hard to start (mainly when cold) eg. it just kicks over and wont start then pops back through the inlet then eventually runs ok-ish
it runs ok until it gets to 3-5 psi then splutters and misses and is under power...
my turbo is shagged so its blowing oil into the inlet and the factory bov was putting oil spray on the AFM so i tried cleaning it with degreaser then metholated spirits, after this it didnt seem to change anything
i then thought coil packs leading to waek spark so i checked over them found 2 that looked like they might need replacing, plugs are less than 6 months old but pulled them out to see if they had carboned up... and they look slightly black but still in good condition
its kind of like its leaning out under boost maybe but no pinging, no raised engine temp, and plugs dont look burnt,
no oil in water, no water in oil, not losing water so doubt its head gasket
i just cant work out what it might be... asked a couple of mates and they have no idea either...
could it be the AFM on the way out and messing up the fuel mix
any ideas or info would be much appreciated :)
https://www.sau.com.au/forums/topic/186009-rb20det-losing-power-under-boost/
havent checked that yet... can that just happen and it be fine to drive under boost?
spoke to a mate with a rb like mine in his silvia and he said i'm having fuel pressure issues and it might be pump or filter as what i discribed was what his did so i'm gonna have a look at my filter and pumps now and see if anything comes up
Check the fuel filter.
Plugs may look fine but maybe the gaps are out.
Maybe bad batch of fuel?
Also have a look/check your intercooler piping incase something has popped off.
Don't think it would splatter if it was running lean. By the sounds of it it seems as if its over fueling.
Hope that helps some how.
not the fuel... same tank as when it was running well...
how could the gaps change from when i gapped them when i put them in?
checked the filter just then... now i just have a strait bit of pipe where it was
just checked the pumps... tried reversing them to blow out anything stuck in them... managed to kill my low pressure but thats no biggie as i have 2 spares....
if its a fuel thing i'd have to say the high pressure pump isn't pumping good pressure making it hard to start and bad when on boost... but its a bit of money to spend on just a hunch
not meaning to shoot anyones ideas down... i'm just trying them as i go and writing them out
thanks for the help everyone
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
