For sale I have apair of 6 month old HKS 2530's Only problem is the bearings are shot. Basicly the wheels and housings are perfect the bearings need replacing. I have been quoted approx $1000 by GCG to repair them
Im asking 1000 for them but if you think its not a fair price or want a quote before buying then feel free to do so/ make an offer
https://www.sau.com.au/forums/topic/186464-hks-2530s/
The engine they were fitted do spun a bearing during run in and basicly took everything out with it, turbos were obviously damaged, cams, crank the whole lot.
New turbos were fitted to get the car back on the road faster as the turbos were not checked till they were about to be re-fitted to the engine.
It was running OEM actuators with no controller so just 1 bar but was only running the engine in so they never really seen any work.
https://www.sau.com.au/forums/topic/186464-hks-2530s/#findComment-3380369
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
